OK guys I finally got my truck (Project burned out engine compartment ) where I can drive it now after getting the correct year ECM, its a 2k dodge dually auto truck, I still have a few problems though. The first is the trucks starter will just clicks, like the relay is not working right, it will also do this in any gear, like a ground is not working some where, I take the starter relay off (new relay) and put on a jumper wire bypassing the relay and truck starts up with no click, whats wrong here? then after truck starts up code 1899 appears (pnp switch failure code) up on my OTC, I replaced the pnp switch on the transmission and it does the same thing! ok here is problem # 2 , the truck seems like its taking off in 2nd gear, the ECM I got came out of a late 99 year std shift truck, so does my computers need reflashed? is there a better flash program to have the dealer use? what does the dealer usually charge to do this? I want to thank you guys again for the ones who help me by replying to my previous problem ads too! Thanks Guys! at least its drivable! I hope you guys can help me again.
