I have an ongoing problem with a dealership in Oregon that called D/C to void my warranty because of "Extensive Modification--Check signature) when I drove into their facility to check my turbo boost hose connections and they checked and found I only had 9 PSI on the lift pump. (I was getting heavy black exhaust, low boost, high EGT and a loss of some power. )
I don't understand how they could associate my problem with the lift pump, so I assume they check everyone that comes in. To make this story a little shorter than previous posts, my question is: since there was a bulletin # 878 stating the replacement of the limft pump on certain vehicles with certain numbers and character in the VIN of which mine fit into, be replaced under warranty, and I took delivery of the vehicle directly from the dealer and drove it stock up until it appeared it was not going to do a very good job of towing and hauling for me.
After a year I added the modifications listed in my signature. Now the dealership tells D/C I have all the modification which prompts D/C to void my warranty.
Since I took delivery of a vehicle that D/C knew had a problem with lift pumps after it left the factory, and prior to my adding the mods. Should this warranty still be honored regardless of the modifications?
