Originally posted by cditrani
I respectfully disagree. hp is calculated from torque and rpm because that is the only practical way to measure it with a dyno. hp is a measure of how much work is being done. It's work that accelerates you.
Put a wrench on stuck bolt. Apply 10 #' of torque. It's till stuck, so it doesn't move. You are applying 10 #' of torque, but you aren't accelerating anything. You aren't doing any work.
I've read the article you cited, and it doesn't dispute anything I've said. This is subtle stuff, and it took me several years as a physics major before I really got it.
Well, I have ans associates in physics and mathematics and a BS in Comp Sci so suffice it to say that I have an understanding of the concepts.
You are right they are subtle concepts.
If you have 2 engines. . these are hypothetical but typical ratings
a chevy 350 245hp 350 ftlb
a dodge 383 'B' 236 hp 440ftlb
Which would you want to pull a trailer with??? assume the same gearing and identical manual trannies in similar vehicles.
well the chevy will make it's power at 5200rpm. the dodge will do it at 4500rpm. torque peaks will occur at 3500 and 3000rpm respectively.
the 383 will pull a heavier load better but will not achieve the same top speed.
ina 1/4 mi race the 383 will launch much better and have a much better 1/8mi time but the 350 will beat it to the finish line.
later,
Mark
