I am new to the TDR and was wondering if anyone out there could give me some advice about getting some more power out of my current setup. I have tried turning the fuel delivery screw and adjusting the idle back down but the black smoke was more than I thought was acceptable. I am at 5000 feet here in Idaho, so generating too much heat with extra fuel is also a concern. Here are my current mods...
91 1/2 (fact. intercooler) D 350 5. 9 cummins with banks exhaust, banks turbo, pyrometer,and boost guage, K&N air filter, B&G injectors, Pump removed and recalibrated to 1. 44mm Optima dual battery setup, warn 9K winch, snugtop shell, bedliner,custom front and rear spring packs and overloads, Power Lock in rear differential, KYB gas adjust shocks and steering stabilizer, Sony CD player, new clutch, u joints, brakes, alternator, spider joints. The truck is still very tight considering it has 230,000 miles on it. I run dello 400 15/40 and change religiously every 4K, but I could sure use some more power and paint as well!
