More POWER!
Throttle linkage
Fuel Filter
Opinions wanted: I currently have DD Stage I injectors and am considering a power upgrade. Lets hear your opinions on the options below;
1. Stage II retrofit? (18k mile Stage I's for sale)
2. Fuel / Boost Module? (Which one)
3. Transmission valve body and convertor? (Heard this makes one *ell of a difference)
I have installed several of the PE boxes as well as the Banks kit. I was not convinced that either of these choices was the answer.
Looking forward to comments.
'99 3500 4X4, Quad Cab Red w/Tinted Windows,
Automatic - 3. 54's, Stainless Ultra Boards
4" Exhaust, DD Stage I Inectors K&N Filter, Pillar Mount Boost/Pyro Gauges, Cubby Mount Trans Temp
Ramkids,
While trying these boxes, was it by the “seat of the pants” method or do you mean neither gave you enough?
I tried the EZ and the VA on the DYNO with my stocker and received the following results:
VA: +40HP
EZ: +39HP (No boost elbow)
If its power your looking for why stop at Stage II when you can go to Stage IIIs #ad
Look into DTTs (Bill K) a lot of positive responses about his VBs and TCs. Bill's mods will get you to those Stage IIIs #ad
I have first dibs on the Stage Is #ad
<font color=forestgreen>2000</font> DODGE <font color=forestgreen>RAM</font>, <font color=forestgreen>2500 HD</font>, 4x4 SLT, Reg. Cab, <font color=forestgreen>Forest Green</font>, Agate interior, Cummins ISB, Auto, Shift-on-the-Fly (241HD), 4. 10 LS, ABS, Trailer Tow Group, Camper Group, Michelin; DC: Fog Lights Kit, Tow Rings, Under Rail Bedliner, VentVisors, Splash Guards, Cold Weather Cover, & Mats.
<font color=forestgreen>After-market</font>: JRE 4" Exhaust, Van Aaken, High Idler, Heavy Duty Idler Pulley, Gatorback Belt, Painless Wiring, K40, Viper w/AutoStart, Clarion 6 Disk CD w/remote, UnidenCB w/Francis antenna, Draw-Tite Activator II, Alpex 255TC2C Air Horns, Continental BedRails, Delo 400, HOWES, Liquid Glass.
BigDaddy's Ram #ad
New England RamRiggers
<font color=36648B>2001 PT Cruiser Limited Edition</font>
[This message has been edited by BigDaddy (edited 04-19-2001). ]
Stage III's would definitely require the trans. work at the same time. A friend just installed the DTT VB and Convertor and is totally pumped about it. I need to get with him to drive it. His other mods consist of 4" exhaust and Banks Kit.
The PE and Banks kit impressions was totally seat of the pants, no dyno results.
I am looking for towing power. I'm not looking to turn my 3500 4X4 into a 1/4 miler, I already have that toy.
[This message has been edited by Ramkids (edited 04-19-2001). ]
I can tell you that without a doubt you WILL trash the transmission if you add an EZ or a VA to your DD1's. Get the transmission fixed and then a mild box will really get you some power. I have driven both with DD1's and prefer the older VA and a boost module to the EZ, it has more bottom end power according to my butt-o-meter.
99 2500 QC 4X4 AUTO SB 24V LARAMIE SLT 3. 5 LSD 285-75-16'S SPA Boost/EGT Everything but leather NRA Member Great Lakes TDR Member
DTT goodies so you don't puke the stock transmission an the side of the road,
then the DD2's W/ boost module and elbow and you can tow anywhere
DD3's are not really recommended for the auto by the auto GURU.
2K, 2500, Quad, SB, 4x4, 3:54LSD, A/T w/ DTT VB, TC, TC SAVER and AUX COOLER , REESE 15k 5th slider, EASLEY BULL BAR, MAAP NERFS, BFG-TA's, 9000's,TORQUS MAXIMUS 505 lbft ECM, stealth DD2's, Bully Dog Boost & elbow, ISSPRO pyro, boost & transmission, Turbo Lifesaver, JARDINE 4", PAC BRAKE, MAG HYTECH TP& DC, AFE filter, GEAR VENDORS OD, TAYLOR WING onboard.
pullees:
#1 y2k ARTIC FOX 5th
#2 22' car hauler w/ 76 Pinto 392cid or 68 Cyclone GT Cobra Jet FB
NRA-LIFE, VFW-LIFE, SoCSA-LIFE, SASS
Hey Ramkids, I haven't seen you post for quite awhile. So you caught the fever, I'm shocked. I, too, might be interested in the 4" exhaust. E-mail me if you can do it. Gene
98. 5 24v 3500 2wd 3. 54 lsd pyro & boost in A pillar DD1's E-brake by Jacob U. S. Gear over/direct O'Reilly Air Horns 105 gal aux tank 35' Prowler 5th wheel with three slides Firestone air helper springs
Ramkids,
SR would be interested in the StageI's.
That way I might be able to get out of the way of those sneaky Hitch-Hikers! #ad
Ordered the Hadley Ambassadors today & found a deal on the new mirrors!
Go 'DD2's' + 'EZ' + DTT V/B-(T/C optional, but eventially required) #ad
Y2K Awesome Black LB 3500 QC SLT, 24Valve ETC ISB, 4x4, 4:10 LSD, DTT Custom prepared Auto transmission VB, Power Edge 'EZ', DD2's, K&N, Polished Stull Billet Grill/Fog inserts, Chrome Smitty-Built Step Rails, Mopar Chrome-Tipped Mud Flaps, A-Pillar mounted West-Tach Turbo/Pyro/Trans Temp gauges, Rancho 9000's, Diamond Plated Tool Box, + a bunch of other stuff. Fact:The First Fords' had 'DODGE' Engines! The new PSD's need them!
I'd say if you have the DD1's, and you did try an EZ with those injectors, something wasn't right.
That combination makes for a great seat of the pants feel. But it is too much for a stock auto. Unloaded you may not feel the transmission slipping, but add some load and you'll slip it and you'll know it. This will kill your transmission.
Seriously, consider transmission upgrades, then think about more power.
DD2's and the EZ together are very nice. Intake and exhaust changes are necessary, I feel. transmission mods are mandatory.
Fred Swanson
Co-Owner
Canyon State Components, LLC
www.canyonstatecomponents.com
'00 QC,SB,4x4,Auto,3. 54 w/LSD,Trailer Package,Tow Package,DTT's
TC(91%)&VB(80psi),DD2's,EZ,HOT PE,K&N RE-0880,Cummins RED Valve Cover
