Is there a best, most effective procedure for bleeding injector lines and injection systems?
Yes... AND the fact that you can usually get the engine started with only three properly functioning injectors. When started using only three cylinders, the engine will rattle like hell. Then normally within a few minutes any air trapped in the remaining injector lines will be pushed out and the engine will smooth out.It only mentions three injectors. Is that due to accessibility?
I would not think the lift pump could push it past the injection pump. Meaning, I would not think there would be a clear path through the injection pump.
I am not saying I don't believe you; I just would never have tried that approach.
