Muffler rusted off on 2-year old truck
Lubing front driveshaft - where??
CB Radio Bracket for 3rd Gen?
I can't believe it! I was driving to my mom and dad's last week and the truck suddenly got louder. I checked and the inlet pipe to the muffler rusted off right at the muffler. And this is a 2 year old truck that is run 100 miles almost every day.
The pipe and muffler have a heavy galvanize coating, but the welded the two together with carbon steel wire. So it rusted in a ring right at the weld.
I fixed it for now by brazing it back together. The brazing would not stick to the coating unless I burned through it first. It stuck fine where it was rusted.
I could expect a truck that sits all the time, or one that is driven short miles a day, to have rust due to condensation. But this truck is run all the time.
This truck has had more problems than any other I have had. There are lots of nice things, but I would rather have a 12 valve engine with no computer.
So far, the truck has had these problems:
:( Clutch replaced (under warranty)
:( New PS hose to eliminate vibration (under warranty)
:( Heater box flippers sticking replaced twice (once under warranty - second time at $100 co-pay with intervention from DC customer service):-{}
:( Rear U-joint replaced (under warranty - I replaced again with 351 joint)
:( Left front u-joint (I replaced)
:( Now needs right front u-joint replaced
:( Now needs ball joints replaced
:( Key switch is starting to go bad
If FORD offered a Cummins in their pickups, Dodge would probably go out of business!! :{
Blake
Ford does offer a cummins... just have to buy a 650 or higher... .
i know what you mean about problems. my 2wd is having ball joint issues, but DC wont do anything about it, so i will continue to run them a while longer. my CEL keeps going off for the same couple of codes, but they wont do anything unless i give them the truck for a week. not going to happen. once it fails ill let them have it and they have to give me rental.
Good luck with it and sorry you are having so many problems.
grant
I know. I mean in a regular 3/4 or 1 ton.
I'm hoping for a recall on the ball joints and some of the other stuff. I didn't even think of the exhaust warranty - that probably ran out at 36M. I bet the gassers have stainless steel at least part way back.
Blake
