Details here: TDR Privileges
I went to the dealer and he says this Is normal In the one ton. I don't think so. Any of you had this experence?I don't think this Is normal. My 95 and 99 did not do this.
The play in the drive shaft, is it side to side or up and down; from back to front. I bet you money is the damn U joint's... Do you have a shutter when you slow down or take off?
I was going to post something on my own, but I am having a similar problem. I'll just butt in on your thread. About 100 miles ago (my '03 truck has 75,200 miles on it) I started getting a shutted on deleleration and I am starting to feel it over 55 mph. I figure it is a u-joint, but I had it on the lift today and the joint appears to be tight. There is play in the output slip shaft of the t-case. I am a little worried that I am loosing the rear bearing in the t-case. I am also finding fluid on the frame rails of the truck. I know you can't always tell if the joint is bad until you pull the shaft, which I will be doing this week so I will know more then. I do also realize that a loose joint will allow some wobble and cause fluid loss from the rear seal. When static the seal does not leak and my fluid level is still good.
I guess I was wondering if there is suppose to be some play because on a Jeep NP231 which is just a smaller version of the t-case they is vertually no play in the slip yoke.
Well, I answered my own question. I pulled the ds and the lower universal was seized. I guess the vibrations are causing the t-case to seap oil past the seal. I guess a little play at the t-case is normal.
