2nd Gen Non-Engine/Transmission my 96 1 ton got a 2002 disk brake rear end
Engine/Transmission (1994 - 1998) Price Check
Engine/Transmission (1998.5 - 2002) 275 hp bosch injectors
Just for info-- hard to find a 2002 rearend with 800 mi but if you find something close and want to swap I did it. It went right in all widths spacing ect was the same. the 02 brake hose has the same threads on the frame side as the 96. I swapped the anti lock sensor from the 96 rear end into the 02 and the only thing I had to modify was the 02 emergency brake cable (long one) it was about 8" to long, I took it to a cable shop and they swedged a new end in the right location for 6. 00 $$, STOPS alot better although still a bit spongey pedal. worth the swap!!:) :)
