We all know that the oem lift pump is not very good to say the least, I am on my second pump now and after thinking about the system as a whole I have come to the conclusion that the pump is not the problem, its how it is set up, no pump likes to pull a vaccumn they all want a positive pressure, this theory has been proven to a point by some folks adding a pusher pump, when this is done the oem lift has alot better reliability, the reason is that the pusher is now supplying a positive pressure to the suction of the oem lift pump. With that being said I decided that a pusher was not for me because it just adds one more item to fail, but I would re-design the system that I have , I operate with an auxillary tank 50 gals in the bed of the truck so I plan on plumbing it in as my main supply to the lift, I will also pipe in the return and a seperate gage too, with this setup I will be able to leave the oem pump in its stock location for the heat of the all mighty CUMMINS that is needed in Wyoming, the pump will then get a positive pressure to the suction side and the pump it will have to work less hard = better longivity and reliability. I will then put a small transfer pump on the frame back at the oem tank and use it to transfer fuel as needed to the main feed tank. Also I will have a spin-on filter for 10 microns from the auxillary tank to pick up any forign matter from the supply to keep the screen clean on the lift pump... ... ... Kevin
