Just added one and thought I would share.
Some will remember issue 54 page 14 that had a neat inexpensive approach. I did something similar in that same location but I used a panel with screw terminals that I found here. I thought it would make it more easy to buddy up low current circuits if needed.
As you can see I am only using two out of 6 at the moment. I was going to power it with a relay but decided to splice-loc into pin#1 on the ignition switch. Its (ign & acc on) that uses a heavy gauge wire with 40a fuse under the hood.
