Maybe you guys can help me with a couple questions.
Truck ran fine to work. Shutdown and it sat for about 3 hours and when restarted, it had picked up a very slight rough idle. In the space of about 30 city blocks, rough idle turned into dead hole with lots of smoke out tailpipe and loud popping sound from induction side and tailpipe. Checked oil and water and everything was OK. Never had any sudden noises or abrupt changes. Checked valve adj. and everything was good and everything was opening and closing when it should. Anybody got any thoughts?
Second; Engine passed 416K miles awhile ago. I've got a 1st gen intercooled eng. lined up to do a repower job. I understand the principles of intercooling but am wondering if there are any internal changes between the intercooled and non-intercooled engines like comp ratio, injectors / pump timing? Can/should I run this thing as is and mount and pipe the intercooler as soon as I can, or is the truck grounded until I can get everything hooked up? I'm currently walking, so transportation is pretty high up on my priorities. But not at the expense of the newer engine. I've heard everything from "won't hurt a thing" to "will hurt it big time". What do I do, Dear Abby?
Thanks, Jones
Thanks, Jones
