If I had a hand in D. C. 's HD Ram development.....
The 06' line up would have a C&C option, 4500 series with GVWR's of 30,000 lb, 7 speed stick w double o. d. ( same ratio's as NV 5600 but one higher gear than o. d. 1 ), Eaton 6 speed auto with grade braking feature , 19. 5" wheels with alcoas optional. Dana 135 rear axle with electric locker. Standard ratio of 4:10 with 4:56 and 3:73 options. 2 wd low range feature. 50 gallon fuel tank with an aft axle 50 gallon option, Exhaust brake with both transmissions, Built in electric brake controller with two 7 wire chords, Gauges: Pyro, Boots, FP , Trans T-case, front and rear diff, and the Cummins computer like the big trucks for the engine info, high idle and timer shut down, a better seconday braking system to park besides the E-brake. Regular and QC with more frame length options.
So are there any of the ORIGINAL CHRYSLER GUYS LISTENING? You know, you guys who built the 1st Dodge Cummins ?? This is a message for you !!!
