Did some pulls today on a Dynojet with my new EZ box hooked up. Y2K 2500 ETC -DEE- 2WD-3:54
265-75-16's -BD Stage II Injectors- Psychotty+K&N- BD Boost Module and Elbow. My Dyno numbers before adding the box were: HP-227/ Torq. 454 at the rear wheels. EGT was 1100 D. pre-turbo. This was with just the injectors,boost module and elbow (30# of boost). I don't have a scanner to post all the graphs so I'll just give you the numbers.
After hooking up the Edge EZ Box:
LEVEL 1: (At the rear wheels)
Max. HP & T = 284 - 544. 01 EGT=900 30# boost
LEVEL 2:
Max. HP & T = 285 - 544. 33 EGT=900 30# Boost
Level 3:
Max. HP & T = 285 - 541. 31 EGT=900 30# Boost
The Torque was 540 at 1457 rpm and stayed in the 500's all the way up to 2900 rpm, regardless of box setting. The HP peak (270-285) occured between 2800/3000 rpm, also regardless of box setting.
Is this a little strange or what? Just what is the purpose of the different pin settings if the dyno readings are almost identical no matter the position? Overall,I am happy with the power increases. You can really feel it pull now, but I am concerned about those pin settings. Any comments?
2000 Qc LWB ETC 6Sp 3:54 LSD, + all the options except leather, BD Stage ll Injectors,Edge EZ, Psychotty& K&N,
BD E-Brake with Shifter Control, ISSPRO EGT and Boost Gauges, Transfer Flow 50 Gal. Alum. Fuel Tank, Line X
16K Hijacker Double Rocker, Pulling a 35Ft. triple slide Spinnaker 5vr.
1996 Viper GTS
Suzuki DRZ400
1100 Yamaha Cruiser
LEVEL 2:
Level 3:
1996 Viper GTS
Suzuki DRZ400
1100 Yamaha Cruiser
