My EGT Frustration has finally ended.
One Big Old Clutch...
Here was my frustration. I have an '06, I wanted more power, so everyone said start out with a chip. I opted for the Edge, because it had the gauges and I didn't want to fry the new truck. It had more power, but then I put my toyhauler on the back. The truck got so hot so quick, it hit the 1500 mark on just small hills, and I found that on the big hills I could pull faster if I shut the chip off. Because it was backing down my fuel. So I bumped the temps on the Edge up to 1600, but then I thought this was rediculous, this thing was running so freikin hot.
After reading about them, I finally ordered a HT stainless turbo. I noticed a power difference, but nothing really in EGT's. It gained me a few miles/hour over the hills when towing but I still could hit the 1600 mark even with the box off. By this time I was really thinking about getting a Duramax, I couldn't believe how hot this truck was running.
Then I was at the Sand sport show in Calif. There was a booth with sign that said something about your truck running so hot you can't use it. Immediately I was intriged. They had a very cool looking set of compound turbos on a newer Dodge. I got their brochure, and spent several weeks on the phone with them, they finally let me drive their truck with a trailer on it, and that was enough, I bought one. The company was Diesel Power Source.
Here are the final results. The twins made the truck quieter, a big surprise to me. They definitely made the truck more powerful, and made the turbo lag more like it was with the stock turbo. But the real test was when I went on the deer hunt, towing my trailer again. I hit some big hills, I kept the truck on lvl. 4 the whole time, and held the 70-75 all the time and when I checked the records on my chip later on I never went over 1330 EGT's. However my transmission was showing some slippage on the Edge records. I was so absolutely thilled, I called DPS after the first big hill to tell them about it. They simply asked me to tell everyone I knew, so that's what I'm doing.
Since I did the twins, I have gone nuts, after doing the transmission, I have done injectors, another chip, a Fass, and a dual CP3 pump. The truck still is so driveable, yet fast as crap. Im so glad I didn't get rid of it.
This is a long boring post, but I'm so excited about my find, I had to make a post. I've been reading the TDR for awhile but haven't seen anything about my find. Maybe I was just looking in the wrong places but I now tell everyone, don't sell that Dodge, just do what I did.
After the lessons learned with my '03, I'm going straight from stock to twins on my new truck. No sense in spending money twice! I could have bought a trick set of twins for what I've spent on singles...
On edit:
Wow, that's a deal...
Only $3600 including two turbos...
Not too crazy about the flexible piping, though.
On edit:
Thats one of the places they are saving money, that and HT3B's are about a $4-500 turbo. Between those two items they save you a few undred bucks easy. Using metal tubing instead of the flexpipe will make it stronger and more reliable, but would cost more to fab up, plus the tolerances are alot closer, so they aren't as easy to install. I've seen that setup on Ebay before, though I don't remember the price off the top of my head. A s300-400 twin setup would be more expensive, but I think would perform better in the long run... .
The tubing is what makes this system so great. Think, the other kits use the bent exhaust piping, then couple it with silicone couplers which user two more clamps per tube, that's two more places for lines to blow off etc. Plus I think these have kevlar in them. They are extremely sticky on the inside.
I'm definitely not a turbo expert but I think the top turbo is an HTB2, not an HT3B, it looks nearly idendical to the HT SS I already had.
By the way does anyone know how much I expect to get from my HT SS turbo, I've got some friends wanting it. I paid a ton of $$ for it, and hate to just give it away.
