I have read many threads on where to place trans temp probes and what the values mean. I am posting my observations on my truck for your info:
2003,2500HD, quad cab, Auto pulling 10000 pounds 3200 miles Chicago to Maine and back
Trans temp gages in upper rear test post AND in output cooler line BTW trans and water cooler.
Throughout the trip the trans port read 100-120 degrees on the highway, the output cooler line stayed about 140 at highway speeds and crept up to 180 when slower and in city traffic. During hard pulling up hill, the cooler line had an immediate response up to about 220 degrees with very little change in the trans temp gage.
during prolonged moderate speed driving the two temps did equalize at about 140 degrees. When I tested the temps in overdrive at highway speeds the cooler line (TC) temps fell to 120's with little change in trans temp 120"s
So what does this mean. one thing for sure, from what i've seen on this trip, if you depend on the trans test port temps to gage what is happening for torque converter output temps you will not have accurate data. Second, the trans cooler set up is very efficient at highway speeds and works well at slower speeds.
From now on, I will keep in both probes and use the cooler line temp as my base line. As an aside, a call to DC cust service stated to place the temp probe in the cooler lines.
Do not know if this info is helpful but it may change someones thinking and maybe save a trans.
Happy motoring!
Happy motoring!
