My Favorite Ride Contest
After very much thought i did realise the my favorit ride that id like to get back . really was considerd a wreck. It was a 1974 Peterbilt 352 COE
with a 335 Cummins and RTO12513 trans and 444 ratio SQHD rear ends .
When i bought the truck for $1500 it did not run infact it wouldnt turn over at all . The number 4 babbit had stuck to the crank , I had to have it towed home for $350. 00 , on the way home the driver side front wheel almost fell off of it .
Once i had her home I droped the pan and started pulling main caps .
I found the problem on number 4 the bearing just got hot enough to stick its self to the crank ,due to a cracked oil cooler . But very much to my likeing
I was lucky enough that the crank was in excellent shape with just a minor .
Polish job with emery cloth , a replacement of the mains and a check of the Rod bearings , my old girl was ready to live once again .
Then with some good used tires i could drive my Old Peterbilt . she was definately once wrecked truck as when i retired her for a Kenworth W900 A
When I scraped out the cab it litterly had stop signs welded and pop rivited in the dog house !!!!!!!!!!.
I loved that old truck because it was dependible and got 9 miles to the gallon
loaded down with hay and put 480 Hp to the ground
