PRusin said:
35 trucks is not a HUGE number. :-laf
Still, it could very well be a design/engineering issue, but unlikely considering how many trucks are out there. My guess it had to do with the roads and how are they were driven, causing premature wear. Things like this smack of misplaced responsibility, such as blaming Firestone for tires failing when the real cause is owners don't maintain tire pressure.
As to bellyscraper's problem, still sounds like a tire/wheel/suspension wear/damage issue to me.
2003 Dodge Ram 2500 - excessive vibration when hit bumps while driving over 45 mph
I bought a 2003 dodge ram 2500 in may of 03.
There is a problem with the front suspension on this pickup. When driving 45 mph or higher and after hitting a bump in the road, the front tires start bouncing off of the ground in such a violent way that it will vibrate the pickup off of the road until the pickup is stopped.
I have taken the truck to three different dealerships four times and none of them can tell what is wrong with it. I have called Chrysler in Detroit and have told them that I do not want the truck anymore and they keep brushing me off. I have expressed many times to them and to the dealerships the seriousness of the problem. The last time it went to the dealer for repairs they said that I had a bad steering damper and bad front shocks. If this is the case, then there is a serious design flaw on the front ends of the trucks.
Some one is going to be seriously hurt or killed if nothing is done. I have paid a lot of money for this pickup, and now I am scared to drive it.
My next step is to pursue the Oregon Lemon Law Statutes, But I feel that Chrysler will try to give me another unsafe pickup. I have lost all faith in their product.
Gary John Shukle II
2003 dodge ram 2500
I TO HAVE NOTICED EXCESSIVE VIBRATION AFTER HITTING A BUMP OVER 45 M. P. H
. NOT TO THE EXTENT THAT I'M SCARED OF IT THOUGH.
MY COMPLAINTS ARE IN ORDER OF OCCURRENCE ARE CHECK ENGINE LIGHT 3 TIMES O2 SENSOR-POWER CONTROL MODULE- O2 SENSOR WIRE. FRONT DRIVE SHAFT 4 WHEEL DRIVE LEAK TWICE. FRONT WINDSHIELD LEAK TOP LEFT CORNER. SO MUCH FOR HEAVY DUTY TRUCK OF THE YEAR.
username=Earl Smith
email=earl. smith@valley.net
guestbook=I have a 1995 Dodge Ra m 1500 4WD Extended cab pickup. Since I
bought it I have experienced an unusual ride between the speed of 35 to
48mph. The truck has been in the garage many times since I bought it.
They don't seem to be able to solve the problem. It feels like riding on
a washboard road. It doesn't matter if the road is new or not. CC has put
new drive shafts on, extra heavy duty shocks, new wheels... which by the way
have a real problem holding a balance. No matter what they do I always have
this rough ride at those speeds. With new tires and wheels it's better, but
not gone. I would like to know if anyone else has noticed this problem.
Since I have this problem in my truck I have tried other new Dodge Ram
trucks with no milage on them and they to have the same problem. If anyone
has solved this problem I would really like to know
Dodge RAM trucks, even new Dodge RAM trucks also have common premature front end problems that can lead to loss of Steering control. Symptoms usually include excessive wandering, play in the Steering, vibration and wheel shimmy. DaimlerChrysler repurchased 35 state owned trucks due to front end problems. Although the Dodge RAM is marketed as a durable truck, a DaimlerChrysler spokesman blamed the road conditions in Maine. The founder of the Dodge Truck Steering Problems website had an accident while towing a trailer due to a failed Suspension component that was found "not durable enough". An aftermarket company even recognized the problem and has been manufacturing a better quality replacement for 1994-2001 Dodge RAM trucks. The founder of another website had a 2001 Dodge RAM 1500, which was eventually lemoned back and a 2002 Dodge RAM 1500 Lone Star Edition that also had serious front end problems. With potential loss of control, this issue could lead to an accident turning a RAM truck into a potential death trap.
