The cruise goes throught the computer, but not the TPS
Would you like to explain where the TPS goes and what other processor the Dodge truck has that can take a voltage signal and convert it to a reading the PCM can use to allow upshift to OD.
Philip said:Would you like to explain where the TPS goes and what other processor the Dodge truck has that can take a voltage signal and convert it to a reading the PCM can use to allow upshift to OD.
esamuelson said:I got the speedo fixed today but still have no od. I guess next I will check the voltage on the center wire on the tps and see what I get. Can someone tell me what color wire goes were or what function? There is no plug on my tps, someone soldered the wires direct to the tps and I am wondering if they wired it wrong. My cruise does not work, is that part of the tps or something different?
Paychk said:The cruise goes throught the computer, but not the TPS.
schematics here:
https://www.turbodieselregister.com/user_gallery/displayalbum.php?&userid=5777&albumid=678
Puzzled by your Q, not sure what you are asking? my post was in response to this inquiry:
Philip said:You should have quoted that question. To post that one sentence that the cruise goes threw the PCM but not the TPS might lead people to think the TPS goes somewhere else. I wasn't the only one that posted about that one sentence. It was missleading. You posted an answer. But didn't give anyone a reference to what you were talking about.
You can't check physical operation of the solenoid installed but maybe can if it is off and voltage applied.
