In the last month I've noticed a strange sound coming from my engine. It only happens at start up and lasts until everything heats up. Its sounds like a low moan that vibrates the steering column when I turn to the right. It sounds a lot like what you hear when you drive a vehicle with no power steering fluid in the box. The difference is that this only occurs in two circumstances. The first is when I turn to the right, usually 90* turn at an intersection, Sometimes however, the vibration and moan are still there when the truck isn't moving and is in park. If I step on the accelerator the pitch rises and falls with the RPMs. Once the truck heats up the sound and vibration are gone.
I've checked the power steering fluid, and it is full and clean looking. There is no sign of leaking in the steering, either. I originally thought it might be a problem with the steering column and the U-joints, but the fact that the sound and vibration are present when sitting still and the transmission is in park pretty much eliminate that possibility. The fact that the pitch changes with the engine RPMs indicate that the problem is with a moving part that might be driven by the serpentine belt. I suspect and hope that this sound is coming from the belt. I have 75K on the odometer, so I'm sure there is some wear on the belt, but my quick check didn't find any visible wear on it. Anyone have an idea what this is, or suggestions as to where to look next? I've looked for the source, but I can't pinpoint where it is coming from.
