2nd Gen Non-Engine/Transmission my floor is wet
2nd Gen Non-Engine/Transmission A/C question
Engine/Transmission (1998.5 - 2002) fuel filter needing changing??
I lifted up my floor mat and it the padding is wet. Checked my 98 and it is wet too. More on drivers side than passenger side. The A/C drains are open too. What gives? No smell either.
Mine was soaked, and was coming in from the rear cargo light and ending up in the pasenger floor board. Do a search, there was all kinds of info, some even coming from the A/C drain, which was fixed by adding a piece of heater hose to extend it and point it down.
Tejaas, why the 2 cycle oil? just wondering.
Not Tejas - but the oil is to add lubricity to the fuel to help the pumps live a bit longer - I use it as well...
Are you guys just using the cheapo 2 stroke oils or are you using quality stuff? The reason I ask is because I've seen first hand the big difference in those oils specifically in regard to ash content.
Just curious on the concept... ... ... ... ... ... .....
Ash content is a good question. The lower the better; what do you see as far as brands?
I use Walmart brand 2 cycle oil. From the boat-nut site I frequent the consensus is that Wally oil is repackaged Quick Silver oil. Good stuff.
I would really like to know more about the ash content thing though. Ash = bad news :( I cant pull a spark plug and look at the tip, too much work to pull an injector just for a peek.
Why? Like Gary said, lubricity. There is another TDR member who has 250K on his 98-99 VP-44 and he has added 2cycle oil since new. He is convinced (and me too) that the added lubricity is the reason it is going strong at 250k miles. I prefer 2 cycle oil because it is all lubrication; I dont want cetane boosters, antigel etc. just want some light oil to keep the expensive VP-44 slippery. 2 Cycle oil is very cost effective.
I like the Redline two stroke oils. VERY expensive, but also exceptionally clean.
I do not use 2-stroke oil in my CTD though. I just would rather use an actual diesel additive.
jlh
My passenger side floor board would get soaking wet also. Replaced rear window and RTVed the third brake light cover and still had water in floor. So, I cleaned out the evaporator as well as I could by reaching through the hole where the fan was mounted and then ran a bunch of water through it to clean out the muck. I noticed that the A/C drain was just a tube sticking about 1 inch through the firewall insulation and the insulation was always wet. Got a 90 degree plastic elbow and some tubing and extended the drain down behind the inner fenderwell. Haven't had a problem all summer. Didn't know NAPA had an extension kit for this problem. I had all the stuff for my mod on hand so cost was zip.
Yamalube 2r is a very good quality semi-synthetic; I read in a mag that it's the #1 selling 2-smoke oil (at least in the off-road community). I also heard that the wally world oil is quicksilver. Bel-ray makes a real good synthetic oil as well. Right now I've switched over to amsoil 2-smoke oils after being a life-long Yamalube user; the Amsoil stuff is absolutely amazing.
Wallmart sells Pennzoil synthetic blend, supposedly an ashless 2-stroke oil of excellent quality - about $10 a gallon - it's what I use...
