I have an 01 3500 with DD2, HX40, comp, etc. I made my own fuel supply pump setup a couple of years ago using the Carter pump that was talked about in the TDR. Recently it has started to act weird. The pressure is usually at 14 psi. After about 30 minutes of driving the pressure will slowly climb to 28 psi. I double checked it with a different gauge. I tried removing the fuel cap thinking that maybe pressure in the tank was causing the factory return line to have a restriction, but that did not help. Has anyone else had this problem? Or have any ideas?
Thank you for the help!
