Here is my Fuel system setup. I did this freehand on Photoshop.
This is working really well. at the bottom is my readings of PSI
<img src=https://www.turbodieselregister.com/user_gallery/sizeimage.php?&photoid=5926&width=2/src img>
Here is the Filter Mounted in the hollow of the bed right behind the cab. The top hose is the return from the regulator, the left is the main feed to the Pusher, one of the rights is from the tank and one of them is for the one-way bypass for the pusher pump
<img src=https://www.turbodieselregister.com/user_gallery/sizeimage.php?&photoid=4746&width=2/src img>
Here is the Pusher pump I have mounted on the frame and the one way checkvalve for incase the pusher fails
<img src=https://www.turbodieselregister.com/user_gallery/sizeimage.php?&photoid=4744&width=2/src img>
Pic of Aeromotive Reg. Installed
<img src=https://www.turbodieselregister.com/user_gallery/sizeimage.php?&photoid=4897&width=2/src img>
And a pic of the Regulator itself. Aeromotive # AEI-13301
<img src=https://www.turbodieselregister.com/user_gallery/sizeimage.php?&photoid=4979&width=2/src img>
This setup with the adjustable Regulator is giving me at idle 15PSI, When accel. it drops to 13 or 14 then back to 15 even on freeway. Under WOT it don't go below 13 psi. Flow is increased because of the small head preassure at the filter so even the Pusher pump don't have to work hard.
