Here are some pics of Brian Welliver's 06+ Lunar S bumper. What is really unique about the application is that we incorporated a ram air cold air intake in the outer light mount. I will let Brian give you the specs on how much it reduced his EGTs (I think it dropped it around 200 degrees. We are developing this as an option and it should be available by mid October as an option to our bumpers. Brian is considering either adding ducting on the drivers side to help cool the power steering system as he will be installing a lift with larger tires or mounting an air horn in the light mount.
The kit will include a flanged 5" dia. tube section that will attach the ducting to the stock air box, special ducting that can that allow the diameter to be reduced by twisting the tube clockwise or counter clockwise depending if you want to reduce the diameter or increase the diameter. This allows you to "fit" the tube around factory compenents and since it is made of a polymer you don't have to worry about carrosion. Finally, the recessed light mount is specially sized to allow the ducting to be connected.
Brian: I think I covered everything if not please feel free to elaborate.
