Clutch or other problem, can not get in gear
5 transmissions and 2 clutches in 150,000 miles. First 2 transmission 5th gear failure and dealer error. Next 2 bad remans (STAY AWAY FROM MAN TRAN IN FL!!! 2nd one failed in 200 miles!!), latest trans from Standard in TX is ok. Now for the clutch about 15,000 miles ago I could not get the truck in gear, clutch was not releasing all the way. So I ordered up a SB Clutch and that was fixed. Now again the same problem, am I missing something?? Also under hard acceleration for the last month I get a noise that sounds like bearing that is getting stressed, it has had that noise in 2 transmissions so its not trans. I am thinking I have a bad throwout bearing or mabe a pressure plate problem, what do you guys think. TIA, Karl
