RyanB said:Thanks for the great comments!
Scott- Just found out some bad new's about my brothers minutes ago. Just before he pulled it off the road at the end of October the transmission started to make one hell of a noise... I actually thought it was the dual disk clutch and said we would pull the transmission when I had time. Well, Christmas eve it is I am done in the shop for the day so out we go to look at the truck. Pulled the PTO cover on the 5-speed and sure enough there are gears lying all over the bottom. From what I can see thru the cover there are 2 gears cleaned right off! Funny thing is when it happened he was taking it easy in town here in 3rd gear doing 50kms. I looked at the gears and 80% of them must have been cracked for a while because you can see the old crack and then the fresh break.
Oh well... ***** happens and he will make it better for next year!
He is actually moving up into my class this comming year and will be running twins and water and will actually be able to run weight out the front of the truck which will help him out alot.
Have a good holliday all!!!!
RyanB
WOW... that sucks... ... i guess the only good thing is you found out now instead of hooked to the sled 100km from home
sounds like 07 will be a awesome pulling year!!!!
have a great X-mas
Scott
