This is the second thread in a week that I have come across that made me think I was on the "Other Sites"
WTF!
You averaged 206250 miles per truck, pretty much bought the same motor each time, and I am willing to bet that you tweaked each one of them with a fuel plate and timing.
There is not one thing on this list that I would not expect to see after that many miles on ANY brand of a tweaked truck.
Considering the life expectancy of the PSD's and the Duramax is UNDER 200k before replace and rebuild of the engine (which you did not have to do), I'd say you probably did good.
It is unfortunate that you did not join up with the TDR until last year. Had you known about this site back even when you bought the most recent truck, you could have addressed some of the more serious issues before they were a problem, or saved a ton of $$$ in diagnostics and fixes.
You are going to do what you want, and I would not blame you if you felt that it may be time to switch to a Ford or Chevy after the last 825000 miles in older Dodges. Keep your membership with the TDR if you do switch and when you have a problem with your other brand, and can not get the help you need at the other sites, come on over, and I'm sure someone will help you here.
Good luck in your next decision! May your next diesel be problem free.
WTF!
Posted by SBrandon
P. s. this is my 4th fourth dodge cummins truck I have owned a 1995 single cab dually 2wd 350000 miles, a 96 cab and a half 2wd 205000, a 97 cab and a half 4wd 180000, and this 1998 135000, ALL of these trucks have had at least FOUR of the problems I have listed, just this truck suffers them all. And the killer dowel pin killed this truck it is fixed, .
- 1) water pump
2) ball joints
3) drive shaft
4) transmission (twice)
5) track bar
6) cab leaks water from the roof somewhere
7) transfer case
8) transmission cooler line
9) overdrive button
10) steering box
11) TPS
12) Fuel Sending Unit
13) Oil Sending Unit
14) KDP
