I heard load clunking noise from the rear axle and figured it was time to tow the truck home. After removing the cover i found about 1/2 pound of metal. I can't believe that their are no teeth left on the spider gears. The ring an pinion are ok i think. I have posi, 3. 55, 3/4 ton dana 70,2001 4x4 with 130000 miles. the dealer change the pinion seal and bearing 20k ago make me wonder if he screwed it up?What are my options,Can i put a dane 70(complet axle) from a 93,into my 2001, should i rebuild?,can i do it myself? Can i just put a none posi dif. in my housing cost is a concern. HEEEELP
Thanks Dave
Thanks Dave
