I think that if you look under your hood you'll find that your 05 has a hydraulic booster powered from the power steering pump and no longer has the vacuum assisted brakes.
I currently own an 05 3500 dually and can share with you that the brakes are no different than the 04, and 08 that I owned and have since sold. All 3 of the trucks have great brakes.
One of the brake fluids that's available is a silicon based fluid instead of common brake fluid. . the two are not to be mixed together... .
DOT 4, like DOT 3 and DOT 5. 1, is a polyethylene glycol-based fluid (contrasted with DOT 5 which is silicone-based). Fluids such as DOT 4 are hygroscopic and will absorb water from the atmosphere. This degrades the fluid's performance, and if allowed to accumulate over a period of time, can drastically reduce its boiling point. In a passenger car this is usually not much of an issue as the brakes are generally not used so hard, but can be of serious concerns in racecars or motorcycles due to their much more aggressive braking.
As of 2006, most cars produced in the U. S. use DOT 4 brake fluid.
A different compound of friction, something way off from the stock coefficient of friction could easily create a very hard pedal, and it would require a much higher pressure to stop the truck. The higher the coefficient of friction the higher the pressure to make the brakes function... . Could the brake pads be so hard that your power brake system can't generate the pressure, thus the very hard pedal...
Some racing formulas require a much higher pressure that our trucks were not designed to generate which would show as a hard pedal...
Hope this is some help and gives you some other thoughts... .
