Yo Hoot
2004 Mystery Switch with Pedal and Pressure Switch complete and WORKS!
I finally got around to installing my "Mystery" Switch.
I found a nice pedal switch at Harbor Freight for like $10 or so. I cut the cord off and rewired the internals. Then I used the cord plug for the "out" connection. Real easy. Mounted the pedal on the floor up by the e-brake pedal.
I installed the Hobbs pressure switch that I mentioned earlier.
I decided to do the relay mod instead of the resistor. I pulled the trans relay (#59) and put a small wire, wrapped onto each pin of #30 and #87. Pushed the relay back in place... . no solder required.
Works like a charm. I can hit the pedal at a stop. It will lock up as soon as it gets to about 10-15 mph. Anytime it's chugging more than I like I just hit the pedal once more to unlock.
Downshifting is not pleasant. I turn it off as I'm slowing down. I see me using this more for pulling my 10,000 lb trailer up the steep hills to keep the trans temp down.
Harbor Freight Pedal
Posi-Tap "T"
Posi-Tap "T"
