Details here: TDR Privileges
looking for a j1850 code i found a sensor that is leaking,but i dont know its name. its close to the valve cover o the driver side and i could see 3 of them.
Yep, its oil not fuel. Darn fingers have a mind of their own.
J1850 is not a valid DTC code, it is an interface specification for transmission of data. P codes will be what define specific engine error codes from the ECU. U codes are body and frame codes.
If you are actually getting a code referencing J1850 it is likely telling you the interface is not functioning correctly.
