High coolant temps
Turboman,
I frequently tow at 6000-11000 feet. I'm at 400+HP and I have also experienced high water temps (230*). It seems that any time the boost runs above 30 psi for more than 3-4 minutes the water temp starts to climb. Turning off the A/C helps lower the coolant temp a lot (also lowers egt about 100-150* ) on hard, hot and high pulls .
In an effort to lower the coolant temps I've had the raditor rodded, pressure washed the fins to remove all the bug and other debris, changed to the 180* t'stat, replaced the water pump and tried the water wetter product. Of all of these, cleaning the radiator and charge air cooler seemed to have the biggest impact on temperature reduction. Even with all of the above I can still get to 230* if I really push-it when pulling grades at altitude. At lower elevations I don't seem to have a temp problem although I haven't pulled any of the big grades in the southwest deserts in triple digit heat.
IMO the more power you use the more cooling capacity you will need if you intend on using big power for extended durations of time.
Turboman,
