Need A Box.please Help.
First towing trip with the Juce=Wow!!
OIL Change mess~!
Well Im In Need Of A New Box. pdq Just Informed Me That They Will Not Replace My Volumizer. it's Been Sent Back 7 Times. they Say The Problem Is On My Truck. it's Funny The Truck Runs Fine Without It. i Just Got Use To The Extra Power. looking For New Box . please Help.
2003 1tn Sw Swb 2wd Gauges 5in Exaust Mod Air Box
I did Beta testing for Edge on there Juice w/ attitude box and screen and have to say it works nicely,04. 5 600 2wd 2500 by the way, It took alot for my 99 to get close to the power the 04. 5 has now. Hope this helps. Other people will recommend other boxes but i saw all the testing and safety that went into this one and was impressed.
Also improved the crappy fuel economy to semi-crappy. Hope this helps.
Rich B
Quad Race box, definitely. In cab adjustable, big kick in the rear. Definitely a better option than an EZ (don't hold your breath for a juice/attitude).
Lower pressure, more power! I found that I never used the 30 setting on my 100 box, so I sent it back to exchange for the 140hp model.
I hope I have some self control :D Otherwise Johnny Law will be on my back!
Rhino1
I have a Edge EZ I'm taking off my 03 dodge tonight. It's the older box that has the secret settings. Let me know if you are interested. (PM me) I'm picking up my new O5 dodge tomorrow.
thanks.
SRadke said:
Buy the box first and see what it'll do to a stock clutch. You'll apprecate it more Oo.
-Scott
I just figured that my clutch will last about 6 months or so with the Quad box and my leaden right foot. After I'm forced to upgrade my clutch, I'll start making my way to a set of Piers twins.
TST all the way
But start looking for new rear tires! My duallies were toast in 30-45 days then I learned a little self control (just a little) :D
I will be doing a dyno run with the "NEW" 555 Edge Juice with Attitude on Saturday at BD Dyno Days. I do believe that it is a 'Hot Juice"! Time will tell. Oo. I'll let you know the results! :D
Thanks For All The Info. i Knew I Could Get Some Excellent Advice. does The Quad Or Tst Throw Any Codes ? Thanks Again. Rhino 1
TST is great BUT you have to use some self control, It'll smoke the clutch on anything over level 5 and a turbo upgrade is a good thing also. but if you are going to twin it, the Tst is what I would get.
California 03, AFE, 4" Hog exhaust, 48RE, TST
The TST rocks. Never a code since I installed it at least a year ago. Many miles since then towing a 30' toyhauler loaded between 10-12k. Can tow on 4/4 with no EGT problems, but I help by letting off for shifts when I pull the trailer. Not an EGT problem, just don't want things slipping in the transmission. I tried 5/5 once, and immediately put it back to 4/4. I'm not ready to buy a transmission and turbo yet!
