Need a good exhaust brake switch
How to add class to an ST
Slight pull to right = new steering box (@600miles!)
Anyone know where to get a good low profile push/pull exhaust brake switch that will mount to my stick shift? I'm using a 2 speed axle switch that I got from a big truck shop now but its a bit large and has no mounts so I have it hose clamped on, any better ideas out there?
2001 black dually,4x4, 6 speed H. O. ,loaded up. Jacobs E brake, lighted running boards, toolbox, solor visor, mag hytec cover, rhino lined, diamond tread rail protectors, mud flaps with genos chrome plates, megs exhaust tip, VDO vision series pillar mounted pyro & boost gauges, rerouted blowby bottle, torklift class 5 double tube hitch. Rippin' through the gears with a smile on my face... no more auto for me!
You might want to contact BD. I have one of their exhaust brakes, and I ordered their shift-lever mounted switch. It's a push-pull switch like you described, and it came with a 2 piece aluminum mounting bracket with a center machine screw, it clamped on the shift lever just below the knob. I painted the bracket black to blend in with the shift lever.
Andy
Dune Racer,
Like Andy, I put this switch on my PacBrake. It is really handy. I ordered it from Diesel Injection Service. There are 2 different sizes of transmission shift sticks so you'll need to measure the diameter before you order.
If you like, e-mail me and I'll send you a photo by return e-mail of how it looks installed.
Bill
Y2K 3500QC, 6 Speed, 4. 10, SLT+, Camper & Tow Pkg. , Westin Chrome Nerf Bars, Mopar Flaps, Reese 20K Hitch, V-A CPC, EGT & Boost Gauges, RPM 45 Gallon Aux. Fuel Tank, Highway Products 5th Wheel Toolbox, ECM Controlled PacBrake, Painless Wiring Kit, Mag-Hytec Diff. Cover, 80% Towing Hitchhiker II 31', 2 slideouts, 19,750 GCW
