Need A Good Steering Stabilizer.
Walker Air Sep??
Warning Chime...A different idea!
Looks like the jiuce leaked out of the stabilizer. I was wondering who makes a good one. Would it be better to have a twin stabalizer setup? I drive on quite a bit of gravel roads. lots of ruts & soft spots . Hoping for a little better handling.
95 Ram reg cab, 3/4 ton,4x4,diesel,5spd,K/N filter,4''stacks,no muffler,no turbo silencer,Pioneer cd,Cobra Nighthawk c/b,Wilson whips. OD 113k. . Toys 72 GMC Jimmy, 87 Honda foreman fourwheeler, 97 Arctic Cat ZR 440.
why DODGE it when you can RAM it
I have the twin skyjacker set up and they are ok> If I had it to do over i would stick with the single. It is very noticable and slow to return to center now. A fried of mine had a single rancho(sp?) on his 1500 with 33" tires and it was fine. Have a shop remove the old one because it is a bear to get out of the track bar. I cut mine off flush with the track bar and then drilled in from the front of the truck with a 1/2" drill and beat on the back with a hammer. I just kept going deeper unitl i was able to pop it out. Make sure you find the center when you drill and start small and work up to the 1/2". The shop that he had his done at used an air hammer and it only took five min. Good luck
Tom
96 2500 4x4 nv4500 3:54 slt 3"body lift 2. 5" suspension by skyjacker dual steering stablizers dual front shocks 267/75/16 street tires 36/12. 5/16 swampers for mud silencer ring lost 5" pipe borla KN round style filter JRE stage 2 kit 330/730 JRE afc spring kit boost and pyro gauges
I put a replacement rancho in the stock upper and added a rancho on the tirod, works great for my 35's. Before when the tires got rounded in the front I would get a "wobble" around 45 mph, bad, has not done it in 2 years with 2 stabilizers. Adam
'96 2500 4x4 3. 54 traclok,billit grill,blue head lights,tenzo blue fog lights,clear tail lights w/red bulbs,chrome front & rear dif covers, alumium bed rail covers and tailgate cover,3" stageII lift,35"BFG M/T's on alumium rims, Kenwood sterio system,tinted windows,westach 60lb boost/egt guage,NOS,bullydog LPG injection,360 degree K&N,"tweaked" pump, 4" exaust w/ flowmaster and a 5" tip,Jim Leonard dual disc clutch, 121k,best performances to date=14. 35@97. 8mph(2wd)Weds Mar22,TuesMarch21 351Hp on the motor,394Hp w/ NOS,428Hp w/ NOS and LPG on, You know the rest,yep brand new pherd there tonight, people came and talked tome,said the book says it make 400hp,LOL, running 22. 4 et, HeHe. '98 Prostreet FXR,Kenny Boyce,96" S&S,Thunder Header,Metzler,12. 10et@105mph
Jeff, I did the same thing as MY6EATSV8'S. I have found this is the best setup. I have the dual Skyjackers in the position of the OE Steering damper attached to the frame/drag link. Now there is only 1 shock in the dual bracket. The other is in the toolhouse. Duals on the draglink/frame made no difference than 1. The lower one down on the axle/tierod makes the most difference. Run the 2 like MY6EATSV8'S. Trailmaster & Rancho make good dampers to replace the OE frame/draglink or a kit for the axle/tierod.
Bill R
94 2500 SLT,4X4,5 Speed,3. 54 LSD... . Still looks brand new... .
[This message has been edited by HEMI®Dart (edited 04-09-2000). ]
