We had a technical discussion about Turbos and back pressure at the shop the other afternoon.
The discussion centered around: If you remove backpressure from the after turbo portion of the exaust system, what is the result in manifold Boost PSI: reduced pressure or no change.
The subject vehicle had a gasoline V-6 engine with an aftermarket performace turbo system regulated to 8 PSI of boost. The main focus of the discussion was on peak boost PSI numbers.
One point of view was: The engine will lose boost pressure in the intake manifold because there is a loss of exhaust pressure for the incoming air to build up against.
The other point of view was: Since the turbo is controlled by the wastegate, and the wastegate is controlled (basicly) by manifold pressure ( with ECM input, other control factors ), then the wastegate will simply open later when the boost pressure reaches the desired PSI.
Both viewpoints agreed that the turbo would spool faster with less backpressure, so that is a "Gimmie".
Since this was an aftermarket performance turbo system, we can safely assume that the turbo compressor was not maxed out at 8 PSI and could be dialed to a higher boost setting.
Let's hear some theory.
