OK all you electrical wizards, I need a little wiring advice...
I've got an auxilary set of lights at the rear of my truck fed through a relay that is activated when the truck is put in reverse (tapped the reverse light circuit to trigger the relay) This works great, but now I want to get a little more creative. I'd like to put a switch in the cab so that I can turn on the lights in the back without having the truck in reverse.
How do I go about adding this switch to the circuit? Is there a relay that supports getting triggered by one of two sources? Or is there an alternative wiring scheme I haven't considered?
TIA
Justin
TIA
Justin
