2nd Gen Non-Engine/Transmission Need a picture of a 2002 fuel tank module
ILIANBG
I need to find a fuel tank module. I located a local place that has it-an OEM, in good condition, but they said it came off of a 2000 model. Mine is 2002, and I think it is the same, but they recommended I either bring mine, or have a picture to verify it's the same. No returns. So if I take the tank off, I can't drive it to get it:)
So if someone can confirm that 2000 to 2002 second gen. diesels use the same module, it will really help me, especially a picture. Also, we are talking about the original OEM item, non retrofit with the in-tank lift pump.
Also if someone has a module in good condition and does not need it, please let me know. I need to fix my 1/4 tank fuel supply issues. The last time I dropped the tank, I couldn't clean the screen, so I removed it. Now I wish I didn't.
Thank you!
I fixed mine and put it back in. Should last longer than new. With all the troubles the 98.5 - 02 trucks had with pumps, why not upgrade while you're in there? I definitely would not put a used module in, even if it were free. Just my .02
I don't have the pump retrofit module and I do not want it. All I need is the plastic part, so why does it matter if it's used, if in good, undamaged condition.I have a new float to install and I have a Drawstraw, which has worked great for me. No stock quick-connect fittings- only good marine grade , both diesel hoses and hose clamps. Not much to fail there- really simple, and so far no fuel problems since I removed the factory lift pump. The only issue is sometimes the 1/4 tank, but I almost never let it go that low. But since the float needs replacing again- erratic fuel level reading on the gauge, I am dropping the tank, and while there, will fix the 1/4 tank issue.
The dealer parts guy said the OEM module is not available- only the retrofit lift pump tank module, and I don't want that.
So what do you advise me to upgrade to, since used module is not good?
So, again, back to the original post- does anyone have a picture of a 2002 module? Is module from 2002 and 2000 the same part, or there are differences?
Thank you very much.
Ilian
