2nd Gen Non-Engine/Transmission need apps
Good day all. Where can some one get the apps or also known as thr (tps) With out going to the dealer? thanks for the help
Keith
I've used Hoesli Diesel for a bunch of my Cummins parts. They've got the APPS for about $400.
With that being said, I just replaced my last one with a sensor from Williams Controls for a total of about $140.
I bought the sensor and a wire harness for a Cummins application. The wire harness will have to be modded a bit, since the one side won't plug into the Dodge harness (I used a DT04-6P with gold 16-18ga pins). And you may have to adjust the bellcrank stop in the APPS to take out some deadband. But other than that, it's a drop-in application.
Member TIMBRO sells the sensor and the harness for $160 Shipped. .
Like PC12diver said, the idle needs to be adjusted to eliminate the dead-zone off Idle. . Id set the Idle voltage to . 660 (Instructions explains this)
Member is Timbo - not TIMBRO. Got one from him a while back and it works fine.
