Need BOM # from 93 W250
Performance upgrade chip for 92 dodge d250
92 Dodge D250 sagging front end!
dpuckett
I have a 93 W250 that needs limited slip clutches. Only problem is, there is no BOM tag on the rear diff. My question is, will the limited slip clutches from my dually be the same? I am only replacing the clutches, as the rest of it looks good. The bearings got done (in Jan08, before I bought it), and the (unnamed) shop didnt put the friction modifier in, as AllData didnt call for any #@$%!. Since I didnt pay for it, the shop wont stand behind their work, (just as well, I have forgotten more about 1stGen Dodges than the 4 of them will ever know). So, I have a set of fried clutches, but no BOM # to get new ones from. If the clutches from my dually would work, I'll just give the supplier that BOM #. Make any sense?
It is a 32 spline, 1-1/4 (maybe 1-5/16) shaft.
Daniel
The BOM should be stamped into the rh axle tube in 1/8" numbers, you may need sand paper to find them. If you can't here is a link that might help.
Axle Bill of Material
Gus
