Need cap with flip up front window, rear defrost and wiper!
SmittyBilt Outland Sport Bumper Guard - Back ordered
Who builds them like that?
http://coffeewithJesus. homestead.com/web1.html 89 1-ton, Amsoil System 3000 5-30,K&N air filter, cleaned-up exhaust, Dynomax straight-thru, rebuilt pump, thermostatically controlled twin 14" Permacool electric fans, intercooler), modified 518 OD transmission, Gear vendors OD controler, R-134 refrigernt, louvered front fenders, 93 aftermarket smoothie grille, new Dupont Chromacolor black, black-and-red rubber rubstrip, black headlights, powdercoated bumpers; 78 35'Avion, 93 Lance 900 slide in with generator and power jacks. To see my truck, Click on: <A HREF="http://albums.photopoint.com/j/AlbumIndex?u=1169022&a=10097213
Jesus" TARGET=_blank>http://albums.photopoint.com/j/AlbumIndex?u=1169022&a=10097213
Jesus</A> saves!
good luck!!!!. . ;0
Probably cost as much as a new EXCURSION. . #ad
[This message has been edited by JNutter (edited 01-03-2001). ]
You might hafta do the Frankencamper #ad
thing, starting with a trip to the salvage yard to obtain the wiper from an SUV or minivan (will need about 15A circuit, as I recall). as for the flip-up window, and defogger, I got no idea a'tall #ad
It gets all crappy between the truck window and the camper front window. If the window flipped up, it would be a lot easier to clean. The truck winters in Fargo and Bad Axe.
This idea is about as valuable as snow tires in FL but...
I remember a while back seeing a kit to close off or seal that gap between the truck and camper, which also allows you to remove the rear window if you so desire. Unfortunately I don't remember where I saw it or where to get it. It looked like some sorta rubber seal.
Here's a "cheap" idea, buy some of that rubber pipe insulation at Home Depot, and stuff it between the two... around the outside. #ad
Several years ago I saw an ad for a double magnetic sponge window cleaner for this very task. I want one now, but can't seem to find one. It was like two sponges with a paddle handle on each. You put one on the outside of the glass and one inside. They magnetically stuck together and by moving the one inside the cap or the cab you were able to scrub the outside glass.
Anybody seen one of these?
Shelby
2001. 5 2500 QC LB 4WD, ETH, DEE, 3. 54 gears, Laramie SLT, Camper Special, Trailer Tow, Travel Convenience Group, Power Driver Seat, Alarm System, Remote Keyless Entry, Fog Lamps, Cab Clearance Lamps, HD Transfer Case, Bright White with a Gray Interior. Built 09-15-00, took delivery on 10-06-00, 1749 miles as of 11-25-00. Custom aluminum work body / flat bed. Coming soon: E-Brake and gauges.
Sure have, of all places, look in a pet store that has a full selection of aquarium stuff. They use em to clean the inside glass of a working aquarium.
98. 5' 24v 2500 Auto/3. 54 4x4 SB QC 285-75-16's on Alcoa's. Everything but leather. PIAA 1200's, AMSOIL dual filter relocation system, Smittybuilt Stainless Steel Nerfs, Rhino Liner(Junk), K&N air filter(For Sale)15 year AMSOIL dealer. Time permitting, Soon to include Ultra-lite Pyro,0-50lbs boost, Trans temp in the pillar. Rancho 9000's with in cab adjustment.
OK, Leer makes a cap with a flip-up front window for easy cleaning, but nobody makes one with a defrosting strip built into the rear window, or a rear windshield wiper. Any suggestions there?
Jesus</A> saves!
At one time you could get an electric rear window defroster that stuck on. They were similar to OEM ones now used on most cars. Another way is to use a small auxiliary heater.
For a wiper, could use a marine type, with the short arm, we use them on forklifts. It wouldn't clear the whole window but should clear enough to see out of. You may require a hole in the window frame or glass to install it. Lear caps come in several heights, and some have the same size window, but use a wider frame to take up the extra height.
My truck has a sliding rear window and I ordered the cap with one aswell, each side can be opened independantly for cleaning. I also have opening side windows instead of sliders, which allows access to items at the front of the bed. Email me if you need help finding the wiper or heater and I can look for them up here.
Neil #ad
Neil Copeman 92 D250,LE,limited slip, 16cm turbo housing, Isspro gauges, factory tach option, Lear cap, DC crankdown tire carrier
Hadley air horns, Stealhorse leather seats, e-mail (home): bombedcummins@sympatico. ca
I did; they'll do anything but install a rear wiper and defroster! But they will install a flip-up front window to ease cleaning.
Go marine. Hella (and others) make a squirrel cage 12v blower/defroster (~ 8 amp draw) that would work well.
Andy Raiha
96/2500/4x4/4. 10/5sp/CC
Thanks!
Jesus</A> saves!
