Engine/Transmission (1994 - 1998) need cummings part number for fuel washers
Engine/Transmission (1994 - 1998) Need the BEST Cheapest Single Disk TC
2nd Gen Non-Engine/Transmission D60 Hub part#'s
Need part number for the banjo bolt fuel washers at the 7100 pump inlet. genos part numbers are not correct. would like the cummings part number.
is there a cummings part supplier for the tdr group? I am having a very hard time gettin parts here in rochester NY. The dealer try as hard as they can but cannot come up with part numbers, and of course there price is twice what it should be.
I have online sites for parts,but I need this one fuel washer which costs 1. 25 but shipping is 8. 00. is there a better way????
I will try the website and loook up the number, thanks. Never been so furstrated working on a truck, I guess i am used to goiing to the local auto parts store and getting the part I need, instead of waiting weeks for the part and then its the wrong one. repairs are on the order of weeks, thats hard to accept. .
Part number 3912887
This was a couple years ago, not sure if it changed. Thats the rubber coated metal washer on the main supply line in the side of the pump.
Chris
GM,
I work with the Cummins engines daily and can supply some part numbers for you. PM me some time if you need further assistance.
The bajo fittings on the injection pump use the seal washer #3918192 This is used at the fuel inlet and the outlet (oveflow valve).
GL
that website is great, was able to get that part number as well as others. The washers are cheaper at the dealer than from cummins.
greg
