I have an older PacBrake and the throttle off switch that attaches to a plate on the timing case (I think) had to be replaced as it was worn out. It is situated so that when the throttle is off, the linkage is full forward and it hits this switch, which allows the ex. brake to be activated. This makes sure that the ex. brake is never left on while accelerating. As mentioned above, I had to replace this switch, and the new switch is somewhat stiffer than the old worn-out one, so that the brake will not engage until the RPM's drop to around 1000rpms. So, I thought that I could maybe add a second spring helping the throttle arm and linkage go forward with more force (when you let your foot off the throttle) and trigger the switch. Would there be any ill effects of adding this spring? I don't want to break anything out of ignorance.
many TIA,
Stephan
many TIA,
Stephan
