Need factory fog light switch for torque converter lockup
Hardlined Wastegate........Drill Hole????
fuel plate identity
i'm going to wire a lock-up switch on my 95 2500. i was hoping to use the spot next to my o/d off switch (where fog light would be) with a switch from the dealer. the dealer quoted me $56. 00 for the switch, which is outrageous #ad
has anyone gotten this switch cheaper #ad
I took the blank out, drilled a quarter inch hole just left of center and installed a mini switch leaving the right side of the blank undrilled for a future function. The mini switch is about $5. 00.
I still haven't found a use for the lockup since my truck is stock, I don't have an exhaust brake and I don't drag it. Let me know how it works for you. I thought it might get me up the Cuesta Grade with a little less rpm but all it did was lug the engine down.
Good Luck,
Tom Sjodin
The switch from the a dealer here in my town was $35. I got one at a salvage yard for $10, and I also got the plug for the back of the switch to make the wiring easy.
-Ryan
I was gonna get an extra fog light switch for my reverse lights. Guess I'll try the junk yard, that price is rediculous.
Pete
'97 2500 CC 4X4 5spd Sport
'83 K5 Blazer 350 TBI (ex 6. 2), 39. 5 TSLs, 3" lift, Dana 60/GM 14 blt, Detroits
I also paid $35 for one and it only lasted a year before it wouldn't stay on unless you pushed it just right. Junk yard next time.
nwohsy, use that spot next to the o/d switch but just go to an electronics store and buy a switch that will fit in there top-to-bottom. I hid the side-to-side gaps with black electricians tape installed from the inside. Clean installation, looks good, costs very little.
95 2500 SLT, clubcab, 2wd, longbed, a/t, 3. 54, 152K miles, "all the usual refinements"
I put a rocker switch in that spot. Then later I had more switches than space to put them. I made a custom switch panel and put it in where the stock cup spiller goes. My cup holder now is a Cup Smoothy from Geno's that attaches to the front of the junk box between the seats. Opps, I mean center console. The OD lockout switch is just a momentary make switch kind of like a door bell so I replaced it with a push button on the switch panel. My combo boost/EGT gage is in the hole now.
Joe George
Eureka, CA
'95 2500 CC auto 4X4,3. 54,Combo EGT/boost guage,custom switch panel,PacBrake,TST #5,DTT TC/VB,Automatic motorhome steps on both sides,Foldacover hard bed cover,Cummins chrome kit,Black steel grill guard,Front hitch receiver, KDP 160,000-NM-WT Insurance
The switch to operate the Jacobs E-Brake is the same as the fog light switch except for the "EB" printed on it. Maybe Jacobs has a better price.
1996 Dodge 2500 4X4 SC, SLT,Cummins 12V, 5-spd. , JRE 4" exhaust (my kitty ran away into the woods and the muffler fell off!), TST 280 HP/685 Ft-Lb Uprate Kit, AFC Spring Kit, ATS 3-piece Exhaust Manifold, Chrome Valve Covers, Horton Fan Clutch, Jacobs/Ram Exhaust Brake, MagHytec Differential Cover, Prime-Loc, Rancho RS9000 Shocks, Combo Gauge, K&N Air Filter, Brite-Box, Geno's finger-touch oil pan drain plug, Optima Yellow Tops, no turbo silencer ring, full-time fog lights. As of 5-19-01, 68,522 miles.
