Noticed gear lube leaking from pinion seal on rear end. Pulled the fill plug and notice large amount of metal shavings on plug.
Took it into the dealer on Tuesday to have it checked out. They called me that morning and said it needed new bearings and seals but gears and differential looked O. K. said it would be about $800 to do the job. That night at about 5 o'clock they called me back and said while putting it back together the pinion gear wouldn't tighten up and they stripped the threads on it?
Now they tell me its going to cost about $1900 because it needs a new ring & pinion. :--) Does this sound right? Should I have to pay for it if they screwed up putting it back together? Looked at the pinion gear on Wed and it looks like they cross threaded the nut on the pinion and cranked on it to get it tight and screwed up the threads?
On top of that they're waiting for the ring and pinion to come in and it might be hear on Sat.
Also found out while they were working on it that they wreaked one of the hubs but they said that they would eat the price for that. What can I do or who can I talk to to see if I have to pay for the Ring and Pinion gears. I don't think that I should have to pay for their screw up. Has anyone ever had a problem with a pinion gear not tightening up for some reason. Just in case maybe they didn't screw up.
