My 2000 RWD truck has developed a strange brake pull problem. When the brakes are cold it does not pull. Stops straight like it should.
The first time I noticed this was going east on 80 into Nevada from Calif. Long downhill grade and pulling the travel trailer. I had done moderate braking to keep the speed down to reasonable and noticed a gradual pull to the left. Got worse as we continued downhill. I didn't feel it in the wheel and suspected the trailer brakes so when getting home I went through the trailer brakes brakes and found all OK.
Did a lot of research and finally noticed that it had nothing to do with the trailer. The failure happens only when the brakes get warm (not HOT) with or without the trailer. I don't often do hard braking and always slow down a bit when towing.
So, I took all advice from this site and did the following:
1. New stainless over Kevlar lines front and rear.
2. Changed the fluid and bled thoroughly. (Valvoline Dot3-4)
3. New front rotors, calipers and pads. Calipers from NAPA, Eclipse which are supposed to be fine.
4. New rear calipers. (made sure sliders we properly lubed and calipers are free to travel) Rotors looked new and no runnout.
5. swapped rear pads from left to right as they were almost new and showed no wear.
6. Went to a good frame shop and had alignment checked. Ball joints looked good and toe needed a small adjustment. I watched him and he seemed knowledgeable.
7. Re-bled brakes again.
Truck stills pulls left when the brakes get warm. Never violently, just feels like the truck is shifting towards the on-coming traffic.
So where do I go now???? (other than the nut house!)
