The well is at 350. Fortunatly he problems are above ground. Re-ditched 110 ft and laid new conduit and water line. UPHILL! Hired the trenching and an unemployed worker to finish with a shovel and help lay the pipes. He took direction pretty well.
Replacing all the functional components for the last tme I hope. Finding someone to do a job to my standards (RIGHT) is harder than just doing it myself. At least when I screw up I know who is to blame!
It's easier to just DO it than to redo someones crappy work. The cost of plumbing and electrical components makes me wonder how anyone can afford to build a new home. We built this one about 17 years ago and prices now seem about double.
I'm 72 so it is getting harder, but I ain't gonna give up untill I drop!
When I get under the truck this weekend I will post what I found.
Pulling a well is not difficult, just hard work. You need a device that holds the pipe from going back down and a winch of some kind. I forget what it is called but google it. The real problem is the weight of the water in the line. However if the is no check valve at the bottom it won't be that heavy. Just the weight of the pump, pipe and wire. NOT and hand over hand pull for 500 ft though. Mine is sched 80 PVC with 20 ft threaded sections so it's not that bad. Galvanized would be heavier but holds better in the clamping device. Here is one type available commercially. http://www.americawestdrillingsupply.com/WellPipeClamps.asp A few basic welding skills and you cound buils one.
