I've been tring to track down what sounds like a valve train clatter noise on my '95 12 valve. Several months ago I checked the valve lash and found one or two a little loose, so I re-adjusted all of them to the 0. 010 / 0. 020 spec. On test drive the rattle/clatter continued so I re-checked and all ok. Rattle still persisted on second test drive so for a third time I went through and re-adjusted the valves a little on the tight side (0. 009 intake, 0. 019 exhaust) and inspected valve train components for signs of problems. Still nothing changed, Fast forward to today. The clatter is starting to get worse so once again I checked the valve lash, all still where I last set them. This time around I noticed when at TDC (I always use the timing pin to find tdc) and going thru things #5 intake rocker arm is loose. According to the service manual only cylinder 1, 2 and 3 intake valves should be loose for adjustment. Rotate engine 360 deg and #5 intake continues to be loose along with cylinder 2 and 6 intake valves as they should be. Not sure why #5 intake is loose (0. 09 lash) when #1 cylinder at TDC but I don't think this is right. Could this be the cause of the rattle/clatter noise? Any thoughts would help greatly
