I installed my manifold last evening and came across a minor issue I need some help on. My steel turbo wastegate line has a hold-down tab welded (soldered?) to it that is anchored to the top manifold bolt on cylinder 3 with a second nut. The ATS manifold uses shorter allen-head bolts and makes no provision for this tab. What have you guys done about this? Is the tab soldered and can be heated an removed? Just cut it off with a hack saw? Replace it - solder - a new one on and anchor it under the head of the #3 allen-head bolt?
I know, I know, loose the housing for a 16cm non-wastegated one. I also installed a 14cm wastegated housing last night and I'm not inclined to solve the problem that way just yet!
Oh, yeah. Mine's an early '98 12-valve. Don't know if this makes a difference.
Thanks,
-Jay
BTW: freezing the end pieces and putting the middle piece in the oven really makes assembling it easy. But you better have the spacing right by the time the parts equalize in temperature or you have to fight it putting it on!
Thanks,
-Jay
