This is the fourth lift pump in less than 40,000 miles and I want to relocate the pump back by the tank on the frame rail.
My question is what size is the fuel line and what size is the line from the pump to the fuel filter.
I want to run original line from tank then cut line as it comes out to the frame rail, attach pump, then run rubber line to line that runs into the fuel filter. In other words I need the fuel line size and the line size of the line between the pump and fuel filter. This will put the pump back about 6-8 feet and we all know electric pumps like to push rather than pull fuel.
Are the two lines the same size. I will take the sizes you guys give me and get a fitting that fits in the fuel pump and attach rubber lines to that.
I am hopeing this will keep the pump running longer.
I am also thinking about installing a auxillary tank in truck bed and hooking fuel lines in to that, this way I would have gravity feed from the tank to the lift pump and then the pump could push the fuel the rest of the way. Hopefully after moveing the pump back closer to the tank will be enough and I wont have to put in an auxillary tank.
Ron
Ron
